06-08-2018 22:45
06-08-2018 22:45
I found no documentation on how long a general app(not a clockface) on Ionic/Versa will last before it gets terminated/closed by the system and return to the clockface again? And is there a way to prevent that?
Best Answer06-08-2018 23:15
06-08-2018 23:15
06-08-2018 23:15
See if this helps.
Best Answer06-13-2018 06:36
06-13-2018 06:36
Thanks for your response!
I feel this totally makes sense. I think doing some stress tests might be helpful in this case to predict if the app will be terminated by any chance.
Best Answer06-13-2018 06:57
06-13-2018 06:57
Also I found one relevant post, which points out memory usage overflow might be the cause of a terminated app.
Best Answer06-13-2018 13:38
06-13-2018 13:38
There's also this (see 'Technical Requirements').
