I am developing a clock face which requests WebAPI data through a companion app. I can refresh OAuth tokens manually, by calling a function in the companion App.
What is the recommended practice when it comes to refreshing tokens automatically? I mean, should I do it every X hours? Before every request to the WebAPI? After?
Also, does a token refresh count against the rate limit?
Thanks!
Best AnswerSo, it turns out I found an answer to my question, which I've put to test since yesterday and it is working fine:
Whenever I get new OAuth data, I save it using a function that also saves the timestamp for when it was acquired:
function saveOauthData(oauthData) {
settingsStorage.setItem("oauth", oauthData);
settingsStorage.setItem("oauthtimestamp", Date.now());
Then, before making requests, I use a function to evaluate if what I have stored is expired. When it is, I proceed to refresh tokens before doing the request to the WebAPI:
function isTokenValid() {
let now = parseInt(Date.now()/1000);
let oauthtimestamp = parseInt(Number(settingsStorage.getItem("oauthtimestamp"))/1000) || 0;
let expiresin = JSON.parse(settingsStorage.getItem("oauth")).expires_in || 0;
let secondsleft = expiresin-(now-oauthtimestamp);
if (secondsleft <= 0) {
console.log ("The access_token has expired " + secondsleft*-1 + " seconds ago.");
return false;
console.log ("The access_token is still valid. " + secondsleft + " seconds left.");
return true;
return false;
return true;
