06-12-2025 20:42
06-12-2025 20:42
Hello, I want to develop some new clock faces for my Fitbit Sense. I see that in the developer tutorials, I need to enable Developer Options in my watch, as I intend to do my development on my Linux box. However, I cannot find the Developer Options in the settings app. I also cannot accept the terms and conditions in Fitbit Studio because it does not exist anymore. Where can I go to enable the Developer Options so I can enable the Developer Bridge in my watch?
Best Answer06-13-2025 05:31
06-13-2025 05:31
Hi @Enker I moved your post to the SDK forum, a better fit for your question.
Laurie | Maryland
Best Answer06-13-2025 13:26
06-13-2025 13:26
GAM; see here under 'Using a Fitbit device'. You may find that using linux makes things harder/impossible because I don't think it's one of the supported operating systems.
Best Answer06-13-2025 19:08
06-13-2025 19:08
Good evening,
I do not understand how using linux would prevent me from enabling Developer Mode on my Fitbit watch. It seems the pathway to enable it, Fitbit Studio, does not exist anymore. There is nothing in my watch settings that I can find that would enable it, nor is there anything in the Fitbit app that will let me enable it. Where should I be looking? I see elsewhere that there are mentions of "accepting the terms and conditions", but they date back to a time before Fitbit Studio was removed.
Best Answer06-13-2025 19:16
06-13-2025 19:16
Have you looked in GAM?
