I made an app with a settings page that works on the simulator, but when I loaded it to my device, I can't find anywhere on my phone to open the settings page. What steps do I take on the Fitbit Android app to find the settings page for my app?
Best AnswerAssuming you sideloaded, your app should be listed in the Developer Menu page within the Fitbit app on your phone. If it isn't, swipe down to refresh.
Touch your app and a new page should appear, which contains a link to Settings.
Best AnswerIf you want to access it via the Gallery, you'll need to install it via a private link (from GAM page), or publish it.
Best AnswerThat's the right place. I don't know why Settings wouldn't appear there if your app has a Settings page that works in the sim. Maybe delete app, rebuild and reinstall on watch/phone.
