Hi! I'm curious if anyone has experience with the Tumbler View in how the selected item visual could be achieved? -- i.e. the translucent rounded rectangle displayed on the initial load/display of the view and after the swipe has settled (screenshot attached) -- is it built into the widget or would one approach be to overlay a rounded image?
I use two circles and a rect to create this shape, usually as a symbol for easy reuse, but adding transparency will spoil the effect by showing the normally hidden edges. I don't know what the tumbler view uses.
Best AnswerThank you, you're right, I did try this approach and had the same issue when applying opacity. I also tried setting the layer order to the same level, and also masking, wasn't able to get a desired result.
I haven't tried a 8-bit PNG yet, will have another tinker with it to see if I can get a similar effect.
