02-18-2023 09:00
02-18-2023 09:00
Anyone been able to get CLI working? I followed the Guide here: https://dev.fitbit.com/build/guides/command-line-interface/ installed Node.js and Visual Studio Code and can't get anything to create or import just error messages all over the place. Love Studio and don't want to have to switch but am willing to switch if I can get this thing working. Any Help? I have searched Google and no one has an actual guide for how to get this thing working.
02-21-2023 08:30 - edited 02-24-2023 12:03
Can't explain why but maybe it will work for others as well. I can't run any of the npx or npm command successfully in either Command Prompt or Node.js Command Prompt. While working on workflows with the new applications I found if I run the commands from the Terminal window of Visual Studio Code they all run fine. Good luck to everyone making the transition to CLI.
02-24-2023 11:46 - edited 02-24-2023 11:53
Can't explain why but maybe it will work for others as well. I can't run any of the npx or npm command successfully in either Command Prompt or Node.js Command Prompt. While working on workflows with the new applications I found if I run the commands from the Terminal window of Visual Studio Code they all run fine. Good luck to everyone making the transition to CLI. I updated the post above with the steps to use Terminal windows in VS Code.
02-24-2023 21:20
02-24-2023 21:20
Hi @4IsDesign - thanks for taking the time to provide helpful guidance for CLI.
