I'm totally new to fitbit SDK and trying to install the firmware now. I've downloaded the latest version of fitbit app with my iphone and I've connected my phone with my lonic via Bluetooth successfully. I've registered on Fitbit studio as a developer and agree to the terms of service as well. now I can create project in Fitbit Studio with no problem. According to the get-started instruction, the next step is to wait until my developer access to finalize and I should receive an alert to install the firmware. However, I couldn't see the developer menu on my iphone even after several hours. And I didn't receive any alert as well. I'm sure I'm using the same account by the way. Anyone knows what the problem is? Any suggestions? Thank you.
Hi,
You don't need to wait for a firmware update anymore, those are instructions from the beta program.
https://dev.fitbit.com/getting-started/
Best AnswerThank you for your reply. However, the problem is still there. I'm not able to access Developer menu in my Fitbit mobile app even if I have accepted the Terms of Service. And I can't find Developer Bridge menu in my lonic's settings. Do you know where the problem is ?
Open an incognito browser window, make sure you login with the same user account which you're logged into the Fitbit mobile app. See if it prompts you to accept the terms again.
