Hi, I want to rotate stats on one of my clock faces when the user clicks on the display. So far I have tried the "#cycleview-item", it worked fine until I wanted to put images with the stats (It doesn't work with images). I've read through the documentation & found that "#cycleview-item" is meant for lists.
As I have a very minimalist knowledge of java and how to set this up in the index.view file, I would like if someone can help me? 😁
