04-04-2019 14:09
04-04-2019 14:09
I can tell my watchface not to read the HR sensor, but the background health app still keeps it running (light keeps flashing). Is there a way I can completely turn off the sensor? Also, does the Body-presence use the HR sensor to determine whether or not the watch is on the body?
I'm trying to make a clockface specific to low light environments; Photographic darkrooms in particular (yea, not too many of us left using those, but that's beside the point). Due to the flashing green light on the optical HR sensor, I can't use my Versa in my darkroom (small amounts of red light are okay, blue/green light even in very small amounts is very bad). I expect there are other situations (astronomy?) where the ability to black-out the watch would be beneficial.
04-04-2019 14:20
04-04-2019 14:20
Have a look in the 'Settings' app on your watch. I don't think you can control this via API.
Best Answer04-04-2019 15:24
04-04-2019 15:24
Turning off the HR in the watch settings does not disable the light / optical sensor.
I am hoping to make turning off the light a one button press process, so while that would be better than nothing, I'd still prefer to disable the sensor via API.
Best Answer09-10-2019 16:06
09-10-2019 16:06
give it enough time they will stop working on their own. Fitbit sucks
