08-17-2021 06:03 - edited 08-17-2021 06:06
Hi there, I was just wondering if there's an idiots guide to coding or whether there are some examples of code for clock faces that I can copy and edit accordingly.
I basically want a digital clock face with a background image that also displays steps and distance.
Is it also possible in the settings function to choose from several images?
I've had a play with the existing digital clock template but just want to improve it but haven't got a clue where to start.
https://gallery.fitbit.com/details/c0a388eb-0ab5-4def-b91a-48d51f809e7b
Best Answer08-17-2021 07:04
08-17-2021 07:04
There are lots of open source examples here: https://github.com/Fitbit/ossapps
and an example of using the photo picker here: https://github.com/Fitbit/sdk-photo-picker
Depending on your SDK version, you might need to adjust things slightly. See https://dev.fitbit.com/build/guides/migration/
Best Answer08-22-2021 23:19
08-22-2021 23:19
Hello @fletcherbravo
Back in time when I start to learn Fitbit OS coding (eventually abandoned having seen a lack of future in the platform) I made this Really Basic Clockface that I think could be helpful.
