09-19-2020 14:49
09-19-2020 14:49
I am extremely new to coding watch faces. I've been using Fitbit Studio. I'm doing okay but I cannot figure out how and where (which folders) to add "Steps per hour" to my watch face. I have the steps line up, but I like to get my 250 steps per hour, and I like to see where I am. Can anyone help me with this? Also, how would I add icons to the steps, heartrate, etc?
Best Answer11-18-2020 14:56
11-18-2020 14:56
The actual UI element that displays the "Steps per Hour" metric should be configured within the resources/index.gui file. It could be as simple as a <text/> element that you update based on calculation done in your code.
As for the calculating the steps each hour, all your code will have to go into your app/index.js file. The guide has some basic examples on how you can display images and manipulate UI elements. Other than that, this list of Open Source clock faces and apps is a great reference for figuring out how different styles can be achieved.
Best Answer08-22-2021 21:34 - edited 08-22-2021 21:35
@Kaceyr2000 - Did you try clock faces in the gallery that do that?
such as
SimpleClockPro steps per hour
