06-24-2021 07:59
06-24-2021 07:59
Using Nudge, Nudge-max or Bump.
Is there an established or anyone using an algorithm to generate a normalised vibration sensation across all watches from the same program?
Ie. Simulate the same level of intensity/duration to compensate for hardware/firmware differences.
Currently the Versa always produces a consistent and detectable vibration and is by far the best, and the one to emulate on the others, because
The Versa 2 seems also consistent, but somewhat more feeble.
The Versa 3 / Sense barely produce any vibration, even on the Strong setting, not only that, it gets progressively worse as the battery level decreases.
08-22-2021 20:23
08-22-2021 20:23
07-01-2021 00:06
07-01-2021 00:06
Has anyone had any success with this calling of Vibration on OS 5?
The available patterns from the documentation are:
"alert"
"bump"
"confirmation"
"confirmation-max"
"nudge"
"nudge-max"
"ping"
"ring"
The calling structure seems to be
vibration.start(Name, Repeat, Time, Strength, Ramp);
where:
Name (A pattern name),
Repeat (0-6, 7=infinite),
Time (ms) (5ms granularity),
Strength (1-7, 0=off),
Ramp "yes" to ramp to next point
07-01-2021 04:22
07-01-2021 04:22
It's just the name.
import { vibration } from "haptics";
vibration.start("ring");
07-01-2021 04:40
07-01-2021 04:40
Thanks Jon, but it's not enough to detect the vibration, and it's only for use in issuing an alert.
08-22-2021 20:23
