05-11-2018 17:46
05-11-2018 17:46
I'm wanting to be able to clear an ImagePicker settings component so that it no longer displays a previously-selected image. Other settings components can be cleared dynamically either by an appropriate settingsStorage.setItem(...), settingsStorage.removeItem(...) or settingsStorage.clear(). However, none of these things seems to faze an ImagePicker until the settings page is redisplayed.
Is there a way to reset an ImagePicker while the settings page is displayed? If not, could this ability be implemented;eg, by having the component respond to removeItem()?
Best Answer05-14-2018 12:53
05-14-2018 12:53
Thanks for reporting this, it's a bug. A fix is on its way!
05-14-2018 12:53
Best Answer05-14-2018 13:46
05-14-2018 13:46
**ahem**; just after I found a workaround! I've gotta stop looking for those... 😉
Best Answer05-18-2018 12:23
05-18-2018 12:23
Should be fixed now!
05-18-2018 14:45
05-18-2018 14:45
Yep. Many thanks! 🙂
