10-04-2018 02:44 - edited 10-04-2018 02:46
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi I want to use a toggle in my Clock Face settings and if the toggle is on display an element if its not that hide. Currently I have following code:
settings/index.jsx
<Toggle settingsKey="stepsToggle" label="Steps" />
app/index.js
if (data.stepsToggle){ stpValue.style.visibility = "hidden"; } else { stpValue.style.visibility = "visible"; }
This properly displays settings and when toggle is switched the stpValue is hidden, but after toggling it back it does not appear. Has anyone had similar problem? If so how did you fix it?
Thanks
Accepted Solutions
10-04-2018 02:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-04-2018 02:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Dunno, but try using the 'display' property instead of 'visibility', with values of 'inline' or 'none'.
Just a wild guess...
Gondwana Software
10-04-2018 02:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-04-2018 02:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Gondwana Software
10-04-2018 04:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-04-2018 04:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Try this mate!
if (data.stepsToggle === "false"){ stpValue.style.visibility = "hidden"; } else { stpValue.style.visibility = "visible"; }
10-10-2018 10:45
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-10-2018 10:45
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I'm pretty new to implementing settings pages. Can anyone help me out with adding a toggle switch. Here is what I have right now, and I keep getting an error.
app/index.js
import * as messaging from "messaging"; import document from "document"; let myElement = document.getElementById("myElement"); let test = document.getElementById("test"); messaging.peerSocket.onmessage = function(evt) { myElement.style.fill = evt.data.value; if (data.toggle === "false"){ test.style.text = "hidden"; } else { test.style.text = "visible"; } }
companion/index.js
import { settingsStorage } from "settings"; import * as messaging from "messaging"; import { me } from "companion"; let KEY_COLOR = "myColor"; let tog = "toggle" // Settings have been changed settingsStorage.onchange = function(evt) { sendValue(evt.key, evt.newValue); } // Settings were changed while the companion was not running if (me.launchReasons.settingsChanged) { // Send the value of the setting sendValue(KEY_COLOR, settingsStorage.getItem(KEY_COLOR)); sendValue(tog, settingStorage.getItem(tog)); } function sendValue(key, val) { if (val) { sendSettingData({ key: key, value: JSON.parse(val) }); } } function sendSettingData(data) { // If we have a MessageSocket, send the data to the device if (messaging.peerSocket.readyState === messaging.peerSocket.OPEN) { messaging.peerSocket.send(data); } else { console.log("No peerSocket connection"); } }
settings/index.js
function Colors(props) { return ( <Page> <Section title={<Text bold align="center">Color Settings</Text>}> <Toggle settingsKey="toggle" label="Toggle Switch" /> <ColorSelect settingsKey="myColor" colors={[ {color: 'tomato'}, {color: 'sandybrown'}, {color: 'gold'}, {color: 'aquamarine'}, {color: 'deepskyblue'}, {color: 'plum'} ]} /> </Section> </Page> ); } registerSettingsPage(Colors);
Thank you 🙂
10-10-2018 19:29
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-10-2018 19:29
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
In your app/index.js, it should be like this:
messaging.peerSocket.onmessage = function(evt) { myElement.style.fill = evt.data.myColor.value; if (evt.data.toggle === false){ test.style.visibility = "hidden"; } else { test.style.visibility = "visible"; } }
1) For your fill you didn't reference myColor.
2) Because you were already doing JSON.parse(val) earlier in in your companion, you are no longer treating the toggle as a string and should be treating it as a boolean.
3) In your toggle you didn't reference evt.
4) The style property name for visibility is "style.visibility" and not "style.text".
10-11-2018 10:08
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-11-2018 10:08
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
That makes more sense. I'm still having issues getting multiple settings to work together. I was able to get the toggle switch working without the color picker, i think its something to do with the ".value". Here is what I have it working with.
messaging.peerSocket.onmessage = function(evt) { //myElement.style.fill = evt.data.myColor.value; if (evt.data.value === false){ test.style.visibility = "hidden"; } else { test.style.visibility = "visible"; } }
Thanks for helping me with this.
10-24-2018 16:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-24-2018 16:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Every time I change pages on my watch or switch to another application and then return to the watch-face the settings reset to the original settings but my toggle switch stays in the same position. Do you know how I get the watch-face to check for this setting every-time it is launched/returned to?
10-24-2018 18:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-24-2018 18:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
You should save your settings on the watch using the "file system" API and restore it when the watch face is reloaded.
Look at an example here for saving the settings:
https://github.com/tyuen/THE-watchface/blob/master/app/index.js#L205
10-24-2018 19:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-24-2018 19:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks for that. I have never used the files system for fibit and am a bit unfamiliar. This is what I have below. I'm not using the applySettings function like in the example not sure if that is where my issue lies.
messaging.peerSocket.onmessage = function(evt) { fs.writeFileSync("settings2.txt", evt, "cbor"); if (evt.data.value === false){ // 12h format hours12.style.display = "inline"; hour24.style.display = "none"; console.log("12 hour format"); } if (evt.data.value === true) { // 24h format hours12.style.display = "none"; hour24.style.display = "inline"; console.log("24 hour format"); } } //New file saving function parseFile(name) { let obj; try{ obj = fs.readFileSync(name, "cbor"); }catch (evt){} if(name === "settings2.txt"){ if(obj){ //applySettings(obj); console.log("settings have been saved"); } else{ peerSocket.onopen = () => {peerSocket.send({getAll:1})}; console.log("reapply settings"); } } } parseFile("settings2.txt");
