I just wanted to confirm that the Ionic will have 2 screen resolutions: 272 x 340 and 312 x 390.
I would assume that if we build images to cater to the 312x390 screen res that they would auto scale to the 272x340 just fine, correct? No special handling needed?
There is a single display size: 348x250 @ 302 PPI (29.3mm x 21mm).
I would definitely recommend using relative sizes and positions where possible though.
All I know is that from my sleuthing it looks like one screen resolution and it is 348x250. The small and large sizes seem to be the band only, not the actual device like the Apple Watch does.
Thanks, I had searched and really don't know where I pulled those other 2 resolutions from!
