04-21-2019 13:03 - edited 04-21-2019 13:12
Is it possible to downgrade SDK version to 1 in Fitbit Studio? Only 3.0 and 3.1 are available, but I could see too many problems after the upgrade:
Can I switch to SDK 1 somehow until these issues are resolved? My app has become unusable because of that.
05-02-2019 14:57
05-02-2019 14:57
I'm not sure that SDK1 will solve your issues, but if you really want to use SDK1 then you'd need to use the command line tools. It would be good to look into this black screen issue, have you checked the memory usage?
https://dev.fitbit.com/build/guides/command-line-interface/
"devDependencies": {
"@fitbit/sdk": "~1.0.0",
"@fitbit/sdk-cli": "^1.6.0"
05-02-2019 14:57
05-02-2019 14:57
05-02-2019 16:17
05-02-2019 16:17
It would be nice to have this feature in Studio as well
Best Answer05-03-2019 07:17
05-03-2019 07:17
We can't maintain that many versions of the SDK. You can read more here https://dev.fitbit.com/blog/2019-02-22-our-sdk-deprecation-process/
