01-12-2023 03:20
01-12-2023 03:20
Given this guide https://dev.fitbit.com/getting-started/
Using a Windows laptop with Chrome on a Ethernet network (same network, just not WiFi)
Using a Pixel 6 with Developer Menu mode enabled and Bridge Connected
Using a Sense 2 with Developer bridge mode enabled.
When I try to connect to the Watch
Then it should connect
Actual: Watch isn't found
Can I deploy to the sense?
Note, the watch wants to connect to USB, but even with USB connected, the watch isn't found
If the Sense 2 (TWO) is not supported, please update the documentation.
I assume I would need to use the simulator and publish to the gallary?
How does the USB connection work?
01-12-2023 09:53
01-12-2023 09:53
Hi @MikeBlakeUK - without the SDK for the watch you won't be able to develop or test, even in the Simulator which doesn't support the watch, that is why it is not found.
01-12-2023 22:22
01-12-2023 22:22
Think the reason is that the sense 2 does not Support 3party Apps at the Moment
01-13-2023 02:00
01-13-2023 02:00
Can the documentation be updated to stop people asking about it. e.g. "Sense 2 is not supported"
Do we know if/when the SDK will be released for the Sense2?
