01-12-2023 19:52
01-12-2023 19:52
I want to animate a circle
<svg class="background">
<circle id="demo" cx="0" cy="168" r="50" fill="white" />
<animate attributeName="x" begin="click" from="0" to="168" dur="1" />
</svg>
consider there are other elements too like time and hr
when i click the circle it animates, but it animates when i click other elemets too.
why is this happening?
My temporary solution was to label other elements with pointer-events hidden.
01-12-2023 23:36
01-12-2023 23:36
You will want to use the click event listener and animation execution as detailed in https://dev.fitbit.com/build/guides/user-interface/javascript/
First, make sure to set the attribute pointer-events="visible" on your circle, "demo"
Then in js:
import * as document from "document";
let myCircle = document.getElementById("demo");
myCircle.addEventListener("click", (evt) => {
myCircle.animate("click");
I don't know if "click" is some kind of predefined animation trigger (I wouldn't expect your animation to work at all without js) but you may want to set your animation's begin attribute to something like "enable" instead, in which case the click event listener would look like:
myCircle.animate("enable");
01-12-2023 20:00
01-12-2023 20:00
What does your click event listener setup look like in js?
01-12-2023 20:04 - edited 01-12-2023 20:14
nothing, i didn't add any in .js
01-12-2023 23:36
01-12-2023 23:36
Then in js:
01-13-2023 04:58
01-13-2023 04:58
thanks it worked
01-13-2023 12:16
01-13-2023 12:16
You absolutely can animate in svg only:
Just make sure to close the animated element AFTER the animation like shown in the examples
