I have a Clock Face project written in Typescript, tested with Jest and built with NPM.
By default Jest calculates coverage only for files that have tests. In my case, I have business logic separated from index.ts and covered with tests. However index.ts is not tested and I want it to reflect in the coverage report (right now it shows 100% coverage which is not true). For that reason I added the following configuration to Jest so that it includes all my ts files to the report (including index.ts):
"collectCoverageFrom" : ["app/**/*.ts"],
But now if I run the coverage report:
npm test -- --coverageI get the following errors:
app/index.ts:1:32 - error TS2307: Cannot find module 'clock'.
1 import clock, {TickEvent} from "clock";
app/index.ts:2:22 - error TS2307: Cannot find module 'document'.
2 import document from "document";
app/index.ts:3:27 - error TS2307: Cannot find module 'user-settings'.
3 import {preferences} from "user-settings";
These are the Fitbit APIs and they are somehow not found by Jest.
Question: How to enable code coverage for files that use Fitbit APIs?
Thank you for your answer. Could you please elaborate a bit. I am unfortunately inexperienced in JS/TS and the documentation didn't help much.
Something like this:
module.exports = {
preset: 'ts-jest/presets/js-with-ts',
moduleNameMapper: {
document: '<rootDir>/test/document.js',
document.js then has whatever methods/variables you use exported for use in tests.
Best AnswerAs @LiamFitbit said, you need to mock those modules.
I did that here: https://github.com/SergioMorchon/fitbit-views/tree/master/__mocks__
You can look at jest manual mocks documentation: https://jestjs.io/docs/en/manual-mocks
