01-08-2020 11:27
01-08-2020 11:27
Hello world.
New here. Just started developing a game for fitbit. First I used fitbit studio and made a working prototype in js. But then I read typescript was supported. New on ts and wanted to get used to it for my job. Had trouble getting even console to work.
But then I found this: https://community.fitbit.com/t5/SDK-Development/TypeScript-support/td-p/2990908
And set up the project locally with node and VSStudio. Got the console to work with writing outputs. Still I get css warnings for new fitbit stuff like text-length/x/y (unkown property).
But even worse, how to use style on an element?
this.hud = document.getElementById("hud")!
this.hud.style.visibility = "hidden";
Best Answer01-09-2020 11:06 - edited 01-09-2020 11:06
No answer and just found out about the tiny js memory.
Ok I guess ts is not worth it with only 64k memory. Going back to js and try to simplify things.
Best Answer01-10-2020 02:30
01-10-2020 02:30
You can checkout the #typescript channel on Discord, our resident expert Sergius can probably give some advice. I know there's some specific optimizations which can help reduce memory overhead.
Best Answer03-06-2020 11:19
03-06-2020 11:19
That's because `getElementById` returns just `Element`s that may or may not be `GraphicElement`, the ones that habe the `.style` property.
See an example of what you have to do: https://github.com/SergioMorchon/fitbit-sdk-types/blob/master/test-code-samples/app/user-interface/m...
`document.getElementById('demo') as GraphicsElement `
