07-03-2019
05:41
15:12
JonFitbit
07-03-2019
05:41
15:12
JonFitbit
This is the log I'm getting from running FitBit OS Simulator in the MacOS folder in its package contents:
Checking for update
[08:39:34.361] [info] appsim exit code: null (signal SIGTERM)
[08:39:34.409] [error] appsim stderr: 2019-07-03 08:39:34.409 app[4219:30010] ASSERT_Log: Type: 26 func_addr: 0x07257d80 lr: 0x00000000, file: ../../fb_private/fb_system/fbsys_notification.c, line: 209, func: _removeNotification, expr: false
[08:39:34.667] [error] Error setting email address: Error: Failed to fetch user data. Error: Error: Request failed with status 401: {"success":false,"errors":[{"errorType":"expired_token","message":"Access token expired: xxx. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process."}]}
Update for version 0.7.2 is not available (latest version: 0.7.2, downgrade is disallowed).
[08:39:35.114] [warn] 10 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[08:39:35.119] [info] companionhost->companion: {"method":"devbridge.status","params":{"status":"disconnected"},"jsonrpc":"2.0"}
[08:39:35.120] [info] Shell Client connected
[08:39:35.137] [info] companion->shell: {"method":"devbridge.status","params":{"status":"disconnected"},"jsonrpc":"2.0"}
[08:39:35.139] [info] shell->companion: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[08:39:35.140] [info] companion->companionhost: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[08:39:35.141] [info] companionhost->companion: {"id":0,"jsonrpc":"2.0","result":{"capabilities":{"protocol":{"maxMessageSize":536870912}}}}
[08:39:35.181] [info] companion->shell: {"id":0,"jsonrpc":"2.0","result":{"capabilities":{"protocol":{"maxMessageSize":536870912}}}}
[08:39:35.185] [info] shell->companion: {"id":1,"method":"devbridge.connect","params":{"authorization":"<redacted>","uri":"wss://027-v3-api-soa.fitbit.com:443/dbridge/"},"jsonrpc":"2.0"}
[08:39:35.186] [info] companion->companionhost: {"id":1,"method":"devbridge.connect","params":{"authorization":"<redacted>","uri":"wss://027-v3-api-soa.fitbit.com:443/dbridge/"},"jsonrpc":"2.0"}
[08:39:35.187] [info] Connecting to developer relay
[08:39:35.187] [info] companionhost->companion: {"method":"devbridge.status","params":{"status":"connecting"},"jsonrpc":"2.0"}
[08:39:35.193] [info] companionhost->companion: {"id":1,"jsonrpc":"2.0","result":null}
[08:39:35.194] [info] companion->shell: {"method":"devbridge.status","params":{"status":"connecting"},"jsonrpc":"2.0"}
[08:39:35.194] [info] companion->shell: {"id":1,"jsonrpc":"2.0","result":null}
[08:39:35.306] [info] appsim stdout: [D][08:39:34.409][] Scheduler starting dispatch time: 1562157574409
[D][08:39:35.305][] Fb_AlarmMgr_Clean is running
[A][08:39:35.306][] Houston, this is Versa!!
[I][08:39:35.306][] Simulator control server starting on 127.0.0.1:63981
[A][08:39:35.306][] Press ? anytime for help
[A][08:39:35.306][] Version: 255.1.930 (May 29 2019 05:51:13): f5c4ea4829
[A][08:39:35.306][] GNU_BUILD_ID:
mfgtst $
[08:39:35.306] [error] appsim stderr: [2019/07/03 08:39:35:3062] NOTICE: libuv support not compiled in
[08:39:35.310] [error] appsim stderr: [2019/07/03 08:39:35:3107] NOTICE: Creating Vhost 'default' port -1, 1 protocols, IPv6 off
[08:39:35.312] [error] appsim stderr: [2019/07/03 08:39:35:3121] NOTICE: created client ssl context for default
[2019/07/03 08:39:35:3121] NOTICE: Creating Vhost 'default' port 63981, 1 protocols, IPv6 off
[08:39:35.380] [error] appsim stderr: 2019-07-03 08:39:35.380 app[4219:30083] ASSERT_Log: Type: 2 func_addr: 0x07266dd0 lr: 0x00000000, file: ../../external_libs/koru/source/i18n/uifwk_i18n.c, line: 57, func: prv_get_locale_table_entry, expr: false
2019-07-03 08:39:35.380 app[4219:30083] ASSERT_Log: Type: 2 func_addr: 0x07267170 lr: 0x00000000, file: ../../external_libs/koru/source/i18n/uifwk_i18n.c, line: 375, func: Uifwk_I18n_GetTextMaxLength, expr: false
2019-07-03 08:39:35.380 app[4219:30083] ASSERT_Log: Type: 2 func_addr: 0x07266dd0 lr: 0x00000000, file: ../../external_libs/koru/source/i18n/uifwk_i18n.c, line: 284, func: Uifwk_I18n_GetText, expr: false
[08:39:35.380] [error] appsim stderr: 2019-07-03 08:39:35.380 app[4219:30083] GLUI: Resources/switcher/switcher_main.gui:164: Error 0 Localization returned error, text remains as '_monthday_format_system' in format
[08:39:35.382] [error] appsim stderr: 2019-07-03 08:39 app[4219] (FSEvents.framework) FSEventStreamCreate: _FSEventStreamCreate: ERROR: could not allocate 0 bytes for array of path strings
2019-07-03 08:39 app[4219] (FSEvents.framework) FSEventStreamScheduleWithRunLoop(): failed assertion 'streamRef != NULL'
2019-07-03 08:39 app[4219] (FSEvents.framework) FSEventStreamStart(): failed assertion 'streamRef != NULL'
[08:39:35.384] [error] appsim stderr: 2019-07-03 08:39:35.383 app[4219:30083] ASSERT_Log: Type: 2 func_addr: 0x072f6040 lr: 0x00000000, file: ../../products/common/src/fb_apps/switcher/switcher_grid_order.c, line: 53, func: Switcher_GridOrder_Load, expr: false
[08:39:35.439] [error] appsim stderr: 2019-07-03 08:39 app[4219] (FSEvents.framework) FSEventStreamCreate: _FSEventStreamCreate: ERROR: could not allocate 0 bytes for array of path strings
[08:39:35.439] [error] appsim stderr: FSEventStreamStart(): failed assertion 'streamRef != NULL'
[08:39:35.708] [info] companionhost->companion: {"method":"devbridge.status","params":{"status":"unauthorized"},"jsonrpc":"2.0"}
[08:39:35.714] [info] companion->shell: {"method":"devbridge.status","params":{"status":"unauthorized"},"jsonrpc":"2.0"}
* SentryElectron unhandledError *
Error: WebSocket was closed before the connection was established
at WebSocket.close (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/ws/lib/websocket.js:252:9)
at clearConnection (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/main.js:1:69796)
at /Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/utils/invokeEach.js:11:15
at Array.forEach (<anonymous>)
at invokeEach (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/utils/invokeEach.js:10:7)
at StateMachine.enterState (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/StateMachine.js:125:32)
at StateMachine.executeTransition (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/StateMachine.js:116:12)
at StateMachine.tryHandle (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/StateMachine.js:66:12)
at /Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/HierarchicalStateMachine.js:75:30
at TaskScheduler.execute (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/TaskScheduler.js:29:7)
at TaskScheduler.enqueue (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/TaskScheduler.js:19:12)
at HierarchicalStateMachine.handle (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/finity/lib/core/HierarchicalStateMachine.js:72:24)
at WebSocket.handleUnexpectedResponse (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/main.js:1:68701)
at WebSocket.emit (events.js:182:13)
at WebSocket.EventEmitter.emit (domain.js:442:20)
at ClientRequest._req.on (/Applications/Fitbit OS Simulator.app/Contents/Resources/app.asar/node_modules/ws/lib/websocket.js:639:15)
at ClientRequest.emit (events.js:182:13)
at ClientRequest.EventEmitter.emit (domain.js:442:20)
at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:546:21)
at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
at TLSSocket.socketOnData (_http_client.js:432:20)
at TLSSocket.emit (events.js:182:13)
at TLSSocket.EventEmitter.emit (domain.js:442:20)
at addChunk (_stream_readable.js:279:12)
at readableAddChunk (_stream_readable.js:264:11)
at TLSSocket.Readable.push (_stream_readable.js:219:10)
at TLSWrap.onread (net.js:636:20)
[08:39:35.720] [info] shell->companion: {"id":2,"method":"devbridge.connect","params":{"authorization":"<redacted>","uri":"wss://027-v3-api-soa.fitbit.com:443/dbridge/"},"jsonrpc":"2.0"}
[08:39:35.725] [info] companion->companionhost: {"id":2,"method":"devbridge.connect","params":{"authorization":"<redacted>","uri":"wss://027-v3-api-soa.fitbit.com:443/dbridge/"},"jsonrpc":"2.0"}
[08:39:35.725] [info] Connecting to developer relay
[08:39:35.726] [info] companionhost->companion: {"method":"devbridge.status","params":{"status":"connecting"},"jsonrpc":"2.0"}
[08:39:35.727] [info] companionhost->companion: {"id":2,"jsonrpc":"2.0","result":null}
[08:39:35.729] [info] companion->shell: {"method":"devbridge.status","params":{"status":"connecting"},"jsonrpc":"2.0"}
[08:39:35.730] [info] companion->shell: {"id":2,"jsonrpc":"2.0","result":null}
[08:39:36.129] [info] companionhost->companion: {"method":"devbridge.status","params":{"status":"unauthorized"},"jsonrpc":"2.0"}
raven@2.4.2 alert: uncaught exception after calling fatal error shutdown callback - this is bad! forcing shutdown
[08:39:36.142] [info] companion->shell: {"method":"devbridge.status","params":{"status":"unauthorized"},"jsonrpc":"2.0"}
[08:39:36.163] [info] Shell Client disconnected
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
I did just implement persistent storage. This is after a fresh uninstall. What is going on here?
07-05-2019 07:50
07-05-2019 07:50
This appears to be due to how the simulator handles date/time, and that you'd manually adjusted the system date/time.
07-05-2019 07:50
07-05-2019 07:50
10-17-2019 22:48
10-17-2019 22:48
Hello,
I am facing same issue.
I adjusted date/time manually while testing my clockface and now my simulator does not start.
Is there any way to clear local storage/cache/token ?
I tried re-installing sim, but did not help
Error setting email address: Error: Failed to fetch user data. Error: Error: Request failed with status 401: {"success":false,"errors":[{"errorType":"expired_token","message":"Access token expired: <SOME TOKEN HERE>. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process."}]}
10-18-2019 02:46
10-18-2019 02:46
I haven't been able to run the simulator on Windows for quite a while due to a ECONNREFUSED error. Has happened with the last few versions. I'm a bit stuck!
