10-18-2019 08:45
10-18-2019 08:45
I'm getting the error -->
Settings: Error: text: Is not a valid Component type.
But the Settings API says this should be valid.
Can someone explain what I'm missing or doing wrong?
Thanks
Best Answer10-18-2019 09:44
10-18-2019 09:44
Corrected now.
Either I had the wrong case for text <text> should have been <Text> or that combined with closing and restarting VS Code.
Best Answer10-18-2019 09:34 - edited 10-18-2019 09:35
FYI - I'm using Visual Studio Code and the Fitbit CLI to build and install, the error occurs during the install. I've already created a clock face and was able to build and install this without a problem so I don't think it's the setup. The install is to the Fitbit OS simulator.
10-18-2019 09:44
Corrected now.
