05-05-2018 10:19
05-05-2018 10:19
I'm trying to use the marquee control and it is working fine in the simulator (for either Ionic or Versa) but when running on my Ionic device the control doesn't appear at all. (I'm sure it was working at some point but now it isn't.)
Best Answer05-19-2018 12:09
05-19-2018 12:09
Ok, I've narrowed down the problem here. I am using a transform on a <g> element containing the marquee to apply rotation. This works fine in the simulator but not on the Ionic device. If I remove the rotation transform on the <g> tag, then the marquee shows up. Bummer, I liked the rotated marquee. ![]()
Best Answer05-22-2018 13:32
05-22-2018 13:32
@CraigFis: it seems like a bug, thanks for letting us know, we'll check with the product team.
06-10-2018 09:28
06-10-2018 09:28
Any ETA on a fix for this?
Best Answer02-17-2020 11:10
02-17-2020 11:10
@JonFitbit I just tried this again on latest SDK, and it still doesn't work on Ionic (but does on simulator).
