Hello,
There is some information on the Sensor Guide here :
https://dev.fitbit.com/guides/sensors/accelerometer/#overview
https://dev.fitbit.com/guides/sensors/gyroscope/#collecting-readings-from-the-gyroscope
However, maximum sampling rate is not specified. What is the maximum sampling rate of the accelerometers and gyroscopes ?
Thanks!
Best AnswerMaximum sampling frequency is 100Hz for accelerometer. I believe gyro can go up to 200Hz. We need to add this in the documentation and provide better examples. Thanks for pointing this out!
I was not able to sample higher than about 10 hertz.
See my reply here
I am not sure if the limitation is on the Fitbit side for the Ionic (or a mistake I am making in code) but I have not been able to consistently sample anything higher than 10 hertz at a regular interval or 14 hertz at an irregular interval. The documentation for sensor data does not seem to relate any of these physical/software/os/some other layer limitations.
Best AnswerI am going to assume that the max acceleration of those sensors is a lie.
@larbac wrote:I was not able to sample higher than about 10 hertz.
See my reply here
