Hello all,
is there any possibiltiy to make one project (fba file) for two SDK's?
I have seen in the gallery that there are some watchfaces for all SDK's,
Regards, Joern
Best AnswerI don't think so. SDK version is set in package.json, and you only get one of those per .fba. However, older versions will often run on newer devices (and some pre-SDK5 products were automatically scaled to work on SDK5).
You can have multiple fba files with the same UUID but targeting different SDKs. That could be what you're observing.
Best AnswerHi,
thank you for your reply! I test it out in the moment, but in my opinion the differences between the sdk's are quiet small... 95% of code you can make copy and paste...
Joern
Best AnswerYou're right. Some devs have managed to produce separate SDK4 and SDK5 products from a single codebase using git, I think.
