12-22-2017 21:12 - edited 12-22-2017 22:50
Many of the Clock faces that show weather say they will update more frequently if you input your own Weather API key.
it is winter where I am & it would be so helpful to see on the Ionic if it’s below freezing & rain will create dangerous ice.
Perhaps someone one can help me with this API entry?
12-23-2017 04:10
12-23-2017 04:10
@lilbitcounts2 wrote:Many of the Clock faces that show weather say they will update more frequently if you input your own Weather API key.
Hi @lilbitcounts2,
This is just the general Ionic forum. You'd probably get a better answer posting this on the Web API forum.
12-23-2017 04:27
12-23-2017 04:27
Thank you Davey.
I’ve since found Clock faces that will show Weather & offer a choice of update frequency no API required.
It it would be quite helpful if they were all this way.
12-24-2017 03:41
12-24-2017 03:41
Or maybe someone in the sdk will know
12-29-2017 05:02
12-29-2017 05:02
Have not had any response regarding how to obtain & use a weather API.
Perhaps FitBit can address this??
12-29-2017 08:13
12-29-2017 08:13
I've moved your post @lilbitcounts2 to the board that I requested you to post in. This is where the teckies hang out.
02-04-2018 08:13 - edited 02-04-2018 08:28
API keys are provided by companies like open weather maps. Go to this link https://openweathermap.org/api, to create an API key, I have done this for my clockfaces, it is free. I can't delete this post for some reason. I have a more detailed one below.
02-04-2018 08:24
02-04-2018 08:24
API keys are provided by companies like open weather maps. Click here to go to the API key page. I have created an API key for the clockfaces that I publish, It was free.
11-25-2018 17:55
11-25-2018 17:55
I have an API key. How do I get to the site where I enter the key?
11-25-2018 21:21
11-25-2018 21:21
The API key probably would be entered on the settings page for the app you're using. Check there first.
11-25-2018 22:03
11-25-2018 22:03
01-12-2019 08:47
01-12-2019 08:47
I can’t get a weather api.
Id like to see the weather on my Versa watch face
01-12-2019 11:23 - last edited on 05-24-2020 20:33 by LiliyaFitbit
Thanks. I figured out how to get the weather API. Google it and you will be able to get it as well.
Sent from my iPhone
01-12-2019 11:52
01-12-2019 11:52
01-12-2019 12:11 - last edited on 05-24-2020 20:31 by LiliyaFitbit
As I recall, I had to cut and paste it into the weather app on the Versa.
Sent from my iPhone
03-02-2019 04:28
03-02-2019 04:28
Hi there,
I've just got my ionic and have the same problem, where to put the api key. Could you please tell me what watch face do you use, that gives you weather information without any key?
03-02-2019 04:30
03-02-2019 04:30
How did you get your API KEY into the clock face? There isn't any place to put it, on the settings menu
03-02-2019 09:37 - last edited on 05-24-2020 20:30 by LiliyaFitbit
I use an app on my Versa that requires a key. It wasn’t hard to copy and paste that key. I think I did it within settings, as I recall. Good luck.
Sent from my iPhone
03-02-2019 09:41 - last edited on 05-24-2020 20:30 by LiliyaFitbit
I wish I could remember that. I think you go to the watch face you want, and you’ll find a place to enter the key there. Or, the watch face may have contact info for the developer. Email the developer and ask. I think I am using the kumon watch face. The developer is very responsive.
Sent from my iPhone
03-02-2019 09:44
03-02-2019 09:44
I just figger it out thank you
