10-23-2017 02:47 - edited 10-23-2017 02:48
G'day Team (Australian for Hello!),
I'm a newbie trying to get started with Fitbit development. I thought I'd use one of the clock faces that have been uploaded to GitHub by other Developers for people to play around with .....but is it possible to upload someone else's code into your Project area on Fitbit Studio?
Or do you have to manually enter the code?
Excited but completely lost....Thanks!
Best Answer10-23-2017 05:39
10-23-2017 05:39
You can also just create an empty project and drag/paste the folders and files in it.
10-23-2017 04:27 - edited 10-23-2017 04:27
Create folders and empty files manually, then copy/paste all the code 🙂
(Crikey, cobber!) 😉 Aussie here, too!
10-23-2017 05:39
10-23-2017 05:39
10-23-2017 16:57
10-23-2017 16:57
Thanks mate (Doh!)....didn't occur to me that it would as simple as that!
Works like a charm, I'm up and running!
