If one has the permission to implement an aod clockface he can use your examble at:
https://dev.fitbit.com/blog/2019-12-19-announcing-fitbit-os-sdk-4.1/
There you write sensors has to switched off and in the examble you have the lines
hrm.stop() and hrm.start() depending on the status of the display.
So this says to me if you use an aod clockface you have no heartrate recording while the display is switched off
Is this really the case?
With the aod clockfaces of Fitbit the heartrate is measured continously - Isn't this possible with 3rd party clockfaces?
Best regards
Capitano
Best AnswerThe operating system monitors and records heart rate regardless of whether the current clockface uses the heart-rate sensor or not. I think the distinction is that AOD clockfaces are not supposed to update the display more than once a minute in AOD mode, so there's little point having them monitor HR continually. Clockfaces aren't allowed to display values that could be so out-of-date. The same logic applies to steps, etc: the system always monitors and records them, but in AOD the current step count shouldn't be displayed.
