I started looking into Ionic development and built/installed a test clockface based on the template code.
However, I now can't find a way to get rid of it from the watch itself, choosing a different one from the list on my phone app doesn't replace it.
Have I missed something obvious?
You might need to try rebooting the device and force quitting the mobile app. Sorry
In the "Sideloaded Apps" section?
That's where I thought it would show but nothing appears there at all, it just shows the spinning icon then shows a button saying "No sideloaded apps, reload to refresh". Pressing the reload button just shows the spinning icon again then, after a while, the reload button.
I have an app and a clockface installed from Fitbit Studio.
This did not work. Quit Mobile App, Rebooted watch, rebooted phone, no "Developer" option on (android) mobile app. Now I can't use any other watchface 😞
Best AnswerFactory reset reverted the change but this is not acceptable solution. I guess I'll wait until Fitbit developers come up with a decent IDE/debugging/publishing before I start making my own faces/apps.
If you can't see the developer menu in the mobile app, try this:
I have the same issue and a factory reset was the only thing that fixed it. This needs to be fixed as a factory reset is not a solution that I want to use.
Best AnswerYes, this is very flaky. If you can get the clockface to appear as a side-loaded app, removing it from there seems to do the trick. But it's hit-or-miss.
Yup. Any sideloaded clockfaces will override gallery installed ones. Uninstall from developer page in the Fitbit app and the gallery installed clockface will show.
I followed JonFitbit's instructions, but with the added steps of also connecting and reinstalling the dev watch face in the studio sdk. Doing this re initialised the dev watch face on the phone and returned the option to delete sideloaded app sin the fitbit phone app.
Best AnswerFactory reset is not needed, at least I was able to remove my sideloaded app. Go to Fitbit app on phone, account, ionic device, scroll below "clock face, apps, media" etc. First option is Developer menu. open and click sideloaded apps. I was able to remove mine right here. Then I was able to select a clockface normally and it worked. Again, no factory reset required. I hope this works for other people.
Thank You, that was hard to find but I finally got my clock back to normal.
