Hello there!
Does anyone know what the future of the Fitbit SDK is?
The last published release (@fitbit/sdk 6.1.0) came out 1 year ago. It is not working with a version higher than node.js 14 (EOL April 2023).
Greetings 👋
Hi @mgaesslein - installing node 18 seems problematic but starting with node 14 and upgrading to 18 may continue to work with current or older SDK versions.
Best AnswerThank you! I'll try again and again. But good to know that someone uses it successfully!
Best AnswerThank you! I'll try it.
