For a while I've been publishing two different clock faces for a single look. One for SDK 4.3 and one for SDK 5. In fact I reached out to Fitbit support when they made the split of sdk 4 and 5 where Ionic, Versa 2 and versa lite used 4 and sense, Versa 3 used sdk 5. Thier guidance was to publish two clock faces.
On my last set of submission I'm getting the following rejection...
Please find the issues uncovered during testing below: # you have to submit this build using the uuid ee185abc-1753-4bd1-96ba-866c276a387d, because you created duplicated on your account. The list support will be for versa family, sense and versa 3 and the system will make the difference because of the different build. If you need more details, please contact appgallerysupport.
The uuid specified is the other clockface for other SDK. Does anyone have any guidance of what I should do. It sounds like I need to publish a build for sdk 5 and one for sdk 4.3?
Thanks in advanced
Best AnswerYour conclusion is right. Paste the uuid from the approved product into the package.json for the rejected one, make sure the version number is different, build, then upload to the same GAM project as the approved product.
