03-21-2018 16:40
03-21-2018 16:40
Hi,
I was wondering is it possible to send push notifications from Fitbit Ionic to an android app, for example if a user's heart rate spikes above 90? I'm a bit of a newbie at the moment, so any help would be much appreciated. Thanks!
03-22-2018 06:04
03-22-2018 06:04
There is no direct way to do this, but you could use a web service:
It's a bit tricky, but it's the only way to do it for now.
Best Answer03-22-2018 23:28
03-22-2018 23:28
This would not be as real time as I'd like it to be though. Are there any plans in place to make this sort of thing possible in the future? Thanks for the speedy reply!
04-02-2018 08:49
04-02-2018 08:49
Not in the plan right now, but it would be nice if you can create a feature request about push notification.
