Sometimes I get this errors out of the blue, and sometimes I can't get rid of them:
Error 22 Unknown element 'def'
Error 22 Unknown attribute 'x'
Error 22 Unknown attribute 'y'
In this case, adding transform on <use> broke everything:
<svg class="background">
<def>
<symbol id="block">
<rect x="0" y="0" width="30" height="60">
</rect>
</symbol>
<symbol id="Sw">
<rect x="-15" y="-15" width="30" height="30"/>
<use href="#block" x="-15" y="15"></use>
<g transform="rotate(90)" x="-15" y="15"><use href="#block"></use></g>
</symbol>
</def>
<g id="m" transform="translate(50%,50%)">
<use href="#Sw"></use>
</g>
<text id="myLabel" />
</svg>How to get rid of this bug?
With these specific erors:
it's <defs> not <def>
https://dev.fitbit.com/build/guides/user-interface/svg/#defs
and `x` and `y` aren't valid attributes on the `<g>` element.
https://dev.fitbit.com/build/guides/user-interface/svg/#g-container
