Hello everyone,
I am trying to create a combo button trigger. So when the bottom right side is touched or the bottom right button is pressed. a want pop-up question to appear. this is the code I have so far and is not working. Any help would be greatley appreciated. Thnx
index.js:
import document from "document";
let myPopup = document.getElementById("my-popup");
// Show the popup
myPopup.style.display = "inline";
let btnBR = document.getElementById("btn-br");
btnBR.onactivate = function(evt) {
console.log("Touched/Pressed Bottom Right");
myPopup.style.display = "none";
}index.gui:
<svg id="my-popup" display="none">
<!-- Black background -->
<rect class="full-size" fill="fb-black" />
<!-- Title and text -->
<use href="#mixed-text-center-mid" class="dialog-mixed-text" fill="fb-white">
<set href="#top-padding" attributeName="display" to="none" />
<set href="#header/text" attributeName="text-buffer" to="TEST" />
<set href="#header/text" attributeName="fill" to="fb-magenta"/>
<set href="#copy/text" attributeName="text-buffer" to="This is a test?" />
<set href="#bottom-padding" attributeName="display" to="none" />
</use>
<!-- BOTTOM RIGHT -->
<use id="btn-br" href="#combo-button-lower-right" fill="fb-red">
<set href="combo-button-icon" attributeName="href" to="btn_combo_flag_p.png"/>
<set href="combo-button-icon-press" attributeName="href" to="btn_combo_flag_p.png"/>
<set href="combo-button-stroke" attributeName="display" to="inline"/>
</use>
</svg>widgets.gui:
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<link rel="import" href="/mnt/sysassets/widgets/combo_button_widget.gui" />
<link rel="stylesheet" href="/mnt/sysassets/widgets/dynamic_textarea.css" />
<link rel="import" href="/mnt/sysassets/widgets/dynamic_textarea.gui" />
<link rel="import" href="/mnt/sysassets/widgets/square_button_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/mixed_text_widget.gui" />
</defs>
</svg>
You want to show the popup onactivate, but you're currently hiding it.
