11-03-2018 16:59
11-03-2018 16:59
Is there any way to get raw pulse waveform values from the Heart Rate Monitor?
01-17-2019 13:01
01-17-2019 13:01
Unfortunately the raw data from the sensor is not exposed via the SDK. While I can't comment on the future roadmap, you can submit a feature request here https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features/label-name/sdk/tab/most-kudoed
11-03-2018 17:20
11-03-2018 17:20
No. The best you can get is heart rate snapshots every few seconds.
11-03-2018 17:35
11-03-2018 17:35
11-03-2018 18:14
11-03-2018 18:14
I doubt it. I don't think the hardware samples rapidly enough to enable sub-beat measures of anything to be meaningful, if they're possible at all.
11-04-2018 13:58
11-04-2018 13:58
I cannot find any details but the HRM sensor on Ionic is supposed to be very good and current PPG sensors are easily doing 30-50Hz sampling. Thus in my opinion hardware should not be a problem.
12-27-2018 17:28
12-27-2018 17:28
@JonFitbit Is there any way to get raw pulse waveform values from the Heart Rate Monitor?
01-17-2019 13:01
01-17-2019 13:01
