10-18-2018 05:54
10-18-2018 05:54
When running npm-install, npm automatically detected this security vulnerability in the @Fitbit/sdk-cli package, due to a dependency on an outdated version of lodash. It looks like the fix is straightforward (update the version of lodash used by sdk-cli, see: https://www.npmjs.com/advisories/577) so I'd like to request this change. Thanks.
npm report:
=== npm audit security report === ┌──────────────────────────────────────────────────────────────────────────────┐ │ Manual Review │ │ Some vulnerabilities require your attention to resolve │ │ │ │ Visit https://go.npm.me/audit-guide for additional guidance │ └──────────────────────────────────────────────────────────────────────────────┘ ┌───────────────┬──────────────────────────────────────────────────────────────┐ │ Low │ Prototype Pollution │ ├───────────────┼──────────────────────────────────────────────────────────────┤ │ Package │ lodash │ ├───────────────┼──────────────────────────────────────────────────────────────┤ │ Patched in │ >=4.17.5 │ ├───────────────┼──────────────────────────────────────────────────────────────┤ │ Dependency of │ @fitbit/sdk-cli [dev] │ ├───────────────┼──────────────────────────────────────────────────────────────┤ │ Path │ @fitbit/sdk-cli > vorpal > inquirer > lodash │ ├───────────────┼──────────────────────────────────────────────────────────────┤ │ More info │ https://nodesecurity.io/advisories/577 │ └───────────────┴──────────────────────────────────────────────────────────────┘ found 1 low severity vulnerability in 1796 scanned packages 1 vulnerability requires manual review. See the full report for details.
Best Answer10-18-2018 11:56
10-18-2018 11:56
Thanks for the feedback, we'll get this one updated. Please use security@fitbit.com for any other security related issues.
10-18-2018 11:56
10-18-2018 11:56
10-23-2018 05:34
10-23-2018 05:34
Thanks a lot for the quick response 👍 🙂 Will use the security email in the future, thanks.
Best Answer01-29-2020 01:09
01-29-2020 01:09
Hi,
I have just installed the cli as described here: https://dev.fitbit.com/build/guides/command-line-interface/
But I cannot install the package because of security problems (see below). And there is an unresolved dependency: fp-ts@2.2.0
Best regards
Kay
│ Dependency of │ @Fitbit/sdk-cli [dev] │
│ Path │ @Fitbit/sdk-cli > vorpal > inquirer > lodash │
│ More info │ https://npmjs.com/advisories/577 │
│ High │ Prototype Pollution │
│ Patched in │ >=4.17.11 │
│ More info │ https://npmjs.com/advisories/782 │
│ Patched in │ >=4.17.12 │
│ More info │ https://npmjs.com/advisories/1065
