This work good in settings page:
import { LEVELS } from '../resources/common';
function settingsPage(props) {
let whatever = LEVELS[0].whatever;
}This does not work:
<TextImageRow label="label" sublabel="Sub-Label" icon="../resources/icon.png" />
Why can we access JS, but not other resources? Why must icons be loaded from web/url?
You can do an image import like this:
import cat from '../resources/cat.jpg';
function Imports(props) {
return (
<Page>
<Section title="Import Image Example">
<TextImageRow
label="Example image"
icon={cat}
</Section>
</Page>
registerSettingsPage(Imports);
Best AnswerHi,
I'm facing the same issue - I'm unable to use my resource images on my settings page.
Is there any requirement for the images? I'm trying to use my 8-bit grayscale png icons, as per the docs.
Using the image from the Settings API sample works but I'd like to use my own resources.
I tried your example and it doesn't work (on the current version of the simulator - 0.7.1.2):
import cat from '../resources/stat_hr_solid_16px.png';
<TextImageRow
label="Example image - NOT WORKING"
icon={cat}
<TextImageRow
label="Example WORKING WEB URL image (from docs sample)"
icon="<a href="https://tinyurl.com/ybbmpxxq" target="_blank">https://tinyurl.com/ybbmpxxq</a>"
</Section>
Edit: typo fix.
