05-28-2023 12:39
05-28-2023 12:39
I didn't get any emails about Fitbit Studio shutting down, and I lost a project. It's still on the watch, but I don't have the source. Is there any way to retrieve that project?
Best Answer05-28-2023 21:52
05-28-2023 21:52
Hi @Pixelwelders - you can contact Gallery support they may be able to help.
Did you save a copy of the project locally or even the *.fba [which also contains the source and main elements in usable format]?
Best Answer07-17-2023 06:19
07-17-2023 06:19
We’re extending the time that Fitbit Studio will be available in read-only mode to give you an opportunity to export any projects you currently have within the tool.
You must export your projects from Fitbit Studio before August 15, 2023, after which they will be permanently deleted. This will be your final opportunity to export your projects.
To export, login to Fitbit Studio and export each project to download its source code.
If you are automatically redirected to dev.fitbit.com when attempting to access studio.fitbit.com, you may need to clear your browser cache.
