07-11-2019 03:39
07-11-2019 03:39
Hi guys,
Is there a way to return the closest city name using the geolocation function?
Or do I have to send the lat and long to an API to do a lookup?
Thanks
Best Answer07-11-2019 19:29
07-11-2019 19:29
There is this wonderful GitHub page collecting many, if not all, public APIs.
I used openweather that can give you also what you need.
Best Answer07-11-2019 16:48
07-11-2019 16:48
Hello @harpo666 You need to use an API
Best Answer07-11-2019 16:59
07-11-2019 16:59
Thanks Giampi71.
Any suggestions of which API I could use to get the closest city names?
Thanks.
07-11-2019 19:29
Best Answer07-11-2019 19:44
07-11-2019 19:44
Thanks Giampi71 !
