Sorry, this is an FNG ( <cough> New Guy 🙂 question...
I was messing with the first clock example, and now I want to go back to my standard clock face. I tried disconnecting the developer bridge, I tried reboot, I tried selecting it again from my Android, but it still shows the clock example as a clock face.
How do I exit from my test clock face?
This ought to go in the documentation someplace as should how to get into and out of the developer bridge. I had to fiddle with it to get this to work, the docs didn't seem to be clear on this.
1. Open the Ionic device by selecting the Ionic symbol on your Fitbit App on your mobile device.
2. Select Developer Menu. This will list your clockface/app under the heading "Sideloaded Apps".
3. Select the relevant clock face/app you want to remove.
4. Select "Delete Application" (in red at the bottom of the screen).
Thanks! That works!
Please add that piece of wisdom to the 'getting started with' documentation.
No longer seems to be there.
Anyone got any further wisdom about how to access the developer menu to remove clock faces?
Best AnswerHi @Labondie ,
I just checked it now and I can see the Developer Menu. The device (Ionic/Versa/etc) should be added or paired with your phone first before you can see this.
In the App, go to the Account page and under Devices, you'll see the device you've set-up or paired. Then tap on that then you'll see Developer Menu under Developer section.
Regards,
Kristoffer
Best AnswerThe 'developer' item will only appear if your device is using a Fitbit account that has been used as a developer account. If you've swapped accounts to a non-developer account, it won't appear.
Best AnswerNot available anywhere on my app. Still need help. Very frustrating. I’m so disappointed in this device that I just bought today.
Hi, I had this issue and none of the answers seemed to work. Possibly because mine is a different version. Mine is the Versa 2:
Go to Fitbit app
click on your icon
Click on your device name (Versa 2)
Click on clock faces
Select your original face
Hope this helps!
