08-22-2018 12:53
08-22-2018 12:53
I have multiple groups of items which are displayed together. I want to change the color of these groups without having to change each one by name. Can I do this with <g> or <symbol>?
For example, if I want to change the outline of my battery and its' head...
<g id="batShell">
<rect id="batBody"/>
<rect id="batHead"/>
</g>When I try and do...
batShell.style.fill = "green";
I get an error.
Should this work (meaning, my error is caused by not completely applying it correctly), or would I be better off using <symbol>, or should I just keep defining each one?
Thanks
Best Answer08-22-2018 21:10
08-22-2018 21:10
Use another SVG.
<svg>
<svg fill="red">
<line fill="inherit" />
</svg>
</svg>
08-22-2018 21:10
08-22-2018 21:10
Use another SVG.
<svg>
<svg fill="red">
</svg>
</svg>
