I have a clock face that opens a secondary view, which is a scroll view. I have two questions:
Thanks!
You cannot listen to events from the physical buttons on clock faces. More complex UI are mean to be apps and not clock faces.
As for the default interfaces when you swipe down from top or top from down, there is no way to deactivate them. It's the default behaviour of the smart watch. If you don't scroll from near the top or bottom, you will be able to scroll without any issues.
Best AnswerYou cannot listen to events from the physical buttons on clock faces. More complex UI are mean to be apps and not clock faces.
Best AnswerI note that this thread is now two years old, but has this restriction changed in any way since that time?
I'm facing the exact same issue now: I have a button on my watch face that shows a short, scrollable Tile List of items to select. It's impossible to dismiss without selecting an option, and swiping from the bottom causes Fitbit Today to pop up. Both of these things make for rather terrible UX, and "don't scroll from near the top or bottom" wouldn't be a great requirement for users either.
If I could get confirmation either way, I will update and close my corresponding question on Stack Overflow. Thank you in advance.
Best AnswerHad the same problem. After migrating from sdk4.2 to sdk5 the scrolling starting at the middle of the screen no longer works. It's always a system scroll. I'm still using the Scrollview with one Scrollview Item which is a textarea with a Done button at the top in the header. Except now I have a tap overlay that splits the screen into top and bottom half and the user can page the text up or down under control of the program. You need to make sure there are no more than 5 lines in any page. Not very elegant, but it works.
