Hi,
I'm trying to set the opacity of a few elements back to 1 after I set it to 0 with an animation. Now normally I would set the opacity with the following command:
element.style.opacity = 1;
But this doesn't work. By the way, I use the following animation:
<animate attributeName="opacity" begin="enable" from="1" to="0" dur="0.3" final="keep" />
How can I achieve this?
Thank you in advance
Julian
Best AnswerI've fixed it with a little trick.
When the animation is finished (in my case after 300 milliseconds) I start a function with setTimeout(). This function set all the elements which I fade out with the animation frame to display: none;. I had also to set the animation final to "restore" instead of "keep".
Now I can simply set the display to inline instead of the opacity.
Here a quick example:
animationSecHand.animate("enable");
animationHourHand.animate("enable");
animationMinHand.animate("enable");
setTimeout(function(){
hourHand.style.display = "none";
minHand.style.display = "none";
secHand.style.display = "none";
}, 300);<animate attributeName="opacity" begin="enable" from="1" to="0" dur="0.3" final="restore" />
Of course, this is not a right answer for this topic. If you have a solution how to set the opacity normally, please tell us. Thank you.
