01-05-2022 06:23
01-05-2022 06:23
I'm trying to disable or hide some options of a Select component. I need this since I have several Selects using the same Options-Pool. If an option is used in another Select, it can't be used again.
Here's what we're starting with:
| 4 options, all visible, Option 2 selected |
Now I can't find a way to simply disable options so that it would appear in a faded way and would not be selectable. Any ideas?
Now I tried to hide options 2 and 4 by conditionally not rendering them via the renderItem section:
| It kind of works, but they still take up space, still show the lines and even the checkmark from the previous selection. I guess I'd have to do some CSS manipulation, but I don't have a clue which CSS is used here. |
I guess the next best option would be to manipulate the options-array of the select itself and delete an option entirely. If someone has a clue how to go about this, I'd be grateful.
Here are the code snippets from the two screenshots:
<Select
label="Example"
settingsKey="example"
maxItems="4"
options={[
{ name: 'Sample option 1', disabled: false, value: { icon: 'https://tinyurl.com/ybbmpxxq' } },
{ name: 'Sample option 2', disabled: false, value: { icon: 'https://tinyurl.com/ybbmpxxq' } },
{ name: 'Sample option 3', disabled: false, value: { icon: 'https://tinyurl.com/ybbmpxxq' } },
{ name: 'Sample option 4', disabled: false, value: { icon: 'https://tinyurl.com/ybbmpxxq' } }
renderItem={
(option) =>
<TextImageRow
label={option.name}
icon={option.value.icon}
/> <Select
label="Example"
maxItems="4"
options={[
{ name: 'Sample option 2', disabled: true, value: { icon: 'https://tinyurl.com/ybbmpxxq' } },
{ name: 'Sample option 4', disabled: true, value: { icon: 'https://tinyurl.com/ybbmpxxq' } }
renderItem={
(option) =>
!option.disabled &&
<TextImageRow
label={option.name}
