09-27-2018 06:32
09-27-2018 06:32
I'm trying to get the below select item to display the currently selected currency. I originally tried doing that using `props.settingStorage.getItem('currency')` which works initially but when selected a second time it returns `{"values":[{"name":"USD"}],"selected":[1]}` although per the SDK documentation it should simply return `"USD"` or `"EUR"`.
On a side note, I also want to point out that the Toggle example, copied verbatim from the SDK docs does not work. I also tried modifying it, but the code string is simply displayed entirely without being processed.
What am I doing wrong?
<Select
label={`Currency: ${props.settingStorage.getItem('currency')}`}
settingsKey="currency"
options={[
{ name: 'EUR' },
{ name: 'USD' }
renderItem={
(option) =>
<TextImageRow
label={option.name}
{/* <Toggle
label={`Currency: ${settings.toggle === 'EUR' ? 'on' : 'off'}`}
settingsKey="curr"
onChange={(value) => { props.settingsStorage.setItem('currency', value === true ? "EUR" : "USD") }}
/> */}Answered! Go to the Best Answer.
Best Answer09-27-2018 19:29
09-27-2018 19:29
Fitbit changed something in the way it returns some information. See if this thread helps...
https://community.fitbit.com/t5/SDK-Development/Settings-changed-w
09-27-2018 19:29
Best Answer09-28-2018 13:31
09-28-2018 13:31
Thank you! That was very helpful. It would mean a lot to the dev community if the SDK docs were updated (and the devs warned) to reflect such changes. Currently it feels like I constantly have to walk the trial-and-error path with Fitbit which isn't really the way to code. Especially because you have to manage to keep three devices connected while developing.
Best Answer09-28-2018 19:37
09-28-2018 19:37
For the record, this is the full link (it got truncated in your post):
https://community.fitbit.com/t5/SDK-Development/Settings-changed-what-it-returns/m-p/2940019#M6064
