10-14-2017 05:36
10-14-2017 05:36
I added setting to my watch face and they appear to work. When I install the app and click on the settings on the companion app, they work, but at that point I am still connected to the developer bridge on both my phone and watch.
If I disconnect the phone from the developer bridge, the settings still work, however as soon as I disconnect the phone, from the developer bridge they no longer work. Even if I reconnect the developer bridge, they don't work. The only way to get a new setting to apply is to reinstall the app and change settings will still connected to the developer bridge.
Is this just a developer issue that will go away when the app is published, or am I missing something?
10-23-2017 07:26
10-23-2017 07:26
Over the weekend, my watch stopped getting notifications, so I uninstalled the app on my phone, the watch on the app, and the watch face that I created. When I reinstalled everything, the settings are now working as they should.
I don't know why they didn't work before, but I am guessing that disconnecting and reconnecting the watch to the app fixed it.
10-14-2017 10:01
10-14-2017 10:01
It shouldn't be dependent upon the bridge at all. Perhaps just try relaunching your app after the bridge is off.
10-14-2017 16:52
10-14-2017 16:52
No luck. I have tried many things and I can't get the settings to send once I disconnect the watch from the developer's bridge after loading it.
I tried restarting the app, restarting my phone, restarting the developer bridge, but still nothing. I am essentially using the settings template for the companion app and using the connection pieces in the device file.
When I do reconnect the developer's bridge, I get the following messages:
The Data not sent is the else condition for peerSocket not being open.
The settings send find when I delete the watch face and reload.
10-15-2017 14:47
10-15-2017 14:47
Can you put your project on Github so we can take a look?
10-15-2017 15:12
10-15-2017 15:12
Sure, here is a link:
https://github.com/drb116/BearTimeWatchFace
I am a high school teacher, so the program is basically a countdown program aligned to the bell schedule. The options correspond to the different bell schedules we use. The program could use a little refactoring, but everything works except the options updates.
10-23-2017 07:26
10-23-2017 07:26
10-23-2017 09:26
10-23-2017 09:26
ok, thanks for letting us know.
