Hello,
I'm working on a college project that involves collecting data from the web API at the utmost real-time flow possible. Currently the data is collected every 15 minutes, and I was wondering if there is a way to shorten this period down to 5 minutes. I'm researching the wake-interval API from the companion API, but I'm not sure if I'm on the correct path.
Hope you can help with this issue.
Thanks in advance.
Hi @JavierSR
Unfortunately, the Fitbit defined sync rate cannot be adjusted. But, you are correct that you can build a clock face for the smart watches using the Device SDK (Device API, Companion API) to customize the sync rate. I'll move your post to the SDK forums. Someone should be able to give you guidance on how to pull the data from the smart watch more frequently.
Gordon
wake-interval won't affect the Web API, but can be used to restart the companion component every 5 minutes. The companion component (Companion API) will also need to have an on-device clockface or app (Device API). Whether this needs to be running continuously to collect the data you want depends on what data you want.
The good news is that you can get data several times every second if you use the Device-Companion APIs (while your clockface/app is in use). But getting the comms working is very difficult.
