I'm trying to use v0.8.1 of the simulator on Windows 10 and can't get any touchscreen actions to work with the mouse.
Specifically trying to swipe down to get the control panel, nothing happens, so I can't turn on AOD to test my clockface.
Am I missing something? I'm sure it worked in the previous version.
Worked out the issue (at least for me).
The Simulator doesn't work properly with a Windows custom scaling - if you choose a regular display scaling (100, 125, 150% etc) then it is fine.
A bit of a pain, hopefully is can be fixed, but workaround is fairly easy.
