I'm playing with the documentation and typing it with TypeScript.
Well, I found a couple of issues:
const hr = me.permissions.granted('access_heart_rate')
? new HeartRateSensor()
: null;
if (hr) {
hr.start();
console.log(`activated in hr: ${'activated' in hr}`);
console.log(`typeof activated: ${typeof hr.activated}`);
}App: activated in hr: false App: typeof activated: undefinedI did this check after having no clue about why that check was always false in a condition, although the sensor was already started and giving metrics.
Thanks for this, and your excellent work on the types repo.
I have recreated the issue with `activated`, and it appears to affect all sensors. I've logged this with the firmware team.
I have fixed the `ring` haptic documentation, but the deployment is stuck amongst some other changes.
I've noted your other feedback and will take a look at those next week.
Thank you!
Best Answer@JonFitbit I have to add a new issue, regarding the TextInput setting component and its onChange event. Reproduced with latest SDK & Emulator.
Instead of the value (you can think of a string), as the documentation says, the callback argument is a weird {"name": <value>} object.
<TextInput
onChange={value => {
console.log(JSON.stringify(value));
}}You can see this issue: https://github.com/SergioMorchon/fitbit-sdk-types/issues/58
It would be really nice to have some kind of repository under the Fitbit GitHub https://github.com/Fitbit organization where we can:
* Open issues
* Follow issues
* See the Fitbit OS / SDK etc. milestones
Thanks for the feedback @Sergius, public bug tracker and roadmap is on my list too. I've raised this particular issue about the <TextInput> before, but I would assume that the value format will remain the same for now.
