03-02-2020 10:05
03-02-2020 10:05
How can I make a transparent PNG and colorize it with a color fill on it? I was able to figure it out with a greyscale 8bit image with a black background, but can't get it working with a transparent background. I've seen it done when I decompiled a sample face, so I know it's possible. I'm assuming it's the way the image is saved that makes the difference...
Best Answer03-09-2020 22:22
03-09-2020 22:22
How about having a separate view to display a solid background?
//this is the background
<view id="background">
//the transparent image goes here
<image>...
